In some company the management of OS authorization is not accessible to users.
A good idea would be to manage folders authorization as an option in the search_path or serch.pro
Sample content from search.pro
search_path "D:\Creo\library" ; R
search_path "D:\Creo\Project1\common_part ; R
search_path "D:\Creo\Project1\sub_project1" ; RW
search_path "D:\Creo\Project2\modul_1" ; R
search_path "D:\Creo\Project3" ; RW
This solution would be interesting when the environment does not allow to install a Windchill Pdmlink.
This possibility will also allow better partitioning of objects during exchanges with subcontractors.
