Manual or automatic chose of Licence
During start up of Creo / ProE, you have to chose which licence package you want to use.
If all licences of this package are already in use, Creo / ProE shuts down and you have to restart it.
Why can't the software go one step back and let me chose a different licence?
Why can't the software propose possible other licences?
Or even better, why can't I chose the module I want to work with and Creo can search for available licences itself?
The available licences still can be defined during the installation process.
This would also give us the possiblity to place links on the desktop for a quick start of Parametrics, Mechanica,...
2 Comments
Marco_Tosin
Lars,
when you setup license it could be possible to choose more than one type of license for each command.
In this way (see attached image) if the first type of license is no more available (foundation), the system try to start the second type (foundation advantage) and so on.
olivierlp
Community Manager
Status changed to: Archived
