Mark a KE in the model tree, should open directly edit definition
if someone open a part and mark a KE in the model tree, then should open directly edit definitions.
Right click on the right mouse button, select the command and confirm with OK again.
This is 3 mouse clicks, although you might only want to see the settings.
It would therefore be very helpful if the corresponding menu opens directly.
mark a KE -> Edit Definition opens
mark a embed sketches of a KE -> Sketcher opens
What do you mean? I think, this could be so much more effective!
Thank you ...
1 Comment
olivierlp
Community Manager
Status changed to: Archived
