The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Maximum Stress Report
Creo Simulate should have a method to allow the display of the worst case stresses of multiple load cases.   This behavior would be better then the current practice of showing a total superposition stress state from the various load cases.  The super position method either over reports or under reports the actual stress state.
For instance, I have 3 load cases to review.  I must review each load case individually now.
As an example.  If I had a 1in^2 rod which has two load cases.  1) A 10 lb pushing force along the rod, and 2) a 200 lb pulling force.  Then Creo would display a total stress of 190psi.  It would be better if Creo could display a 200 psi result.
As a bonus feature, the Query function should report the load case which produced the highest stress in the area being queried.
2 Comments
VladimirN
24-Ruby II
You can vote for your idea too.
olivierlp
Community Manager
Status changed to: Archived
