Maximum memory allocation in Simulate
All,
As of today you have the ability to set the default memory allocation set the config.pro option sim_solver_memory_allocation to the desired value - with the limitation of maximum value to16384 MB.
as today models become more complicated ( lattice, generative design geometry etc ) there is a need to remove this limitation in order to improve performance & calculation time.
2 Comments
KenFarley
I notice this limit is the integer maximum of an unsigned 14-bit binary number. I wonder if there is some underlying data structure that relies on this?
ToddKraft
Hi Rami-Noah,
Perhaps the details below can assist you.
Article - CS67576 - How to run Creo Simulate on multi processors (ptc.com)
Document Details - TPI 106426 (ptc.com)
Todd Kraft
Creo Product Manager
