We would like to measure the distance between exploded components/models using DISTANCE. ANGLE works fine, DISTANCE gives the distance from the unexploded state, even though the model is exploded.
Update: this Product Ideas has been marked as a "Duplicate". Anyone interested in supporting this idea should add their vote here: Make Measurements reflect explode state values
