Measure tool expand dialog box config
There should be a config.pro option that allows the measure tool dialog box to be expanded or collapsed by default.  It would potentially have 4 options to be collapsed, setup expanded, results expanded, or both expanded.
4 Comments
dplachinski
6-Contributor
Set config.pro option measure_dialog_expand to yes
obienate
Thanks for the input.  That seems to only expand the "Results" section.  I can already see the results on the box that pops up on the assembly after a measurement.  This covers 2 of the 4 options I listed above, but what I really want is to have the "Setup" section expanded so I can chose different surfaces, but have the "Results" section collapsed because it doesn't help.  I imagine other people have different preferences depending on they work they are executing.
dgschaefer
I have that option set in Creo 2 & Creo 3 and both sections expand for me.
PTCModerator
Emeritus
Status changed to: Archived
