Measurement in status bar
Suggestion: if you select an edge of a part, it should be possible to show the length, radius, diameter... of it automatically in the status bar without starting the analyzing tool.
Also the distance or angle of two selected edges, surfaces should be shown automatically in the status bar.
In most cases this is sufficient enough. If you have to do more complex measurements you can start the analyzing tool.
6 Comments
olivierlp
Community Manager
Hello and welcome to the Community,
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (Questions below). The more details and context you give, the better.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
olivierlp
Community Manager
Status changed to: Clarification Needed
Peter
3-Visitor
1. Describe your environment: What is your industry? development of industrial printing systems What is your role in your organization? cad administrator and cad user Describe your stakeholders. simplification of daily work
2. What product & version are you currently running? PTC Creo 8.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video. Fast and easy measurement without additional mouse clicks.
4. What is the use case for your organization? not only for our organisation, it will be usefull for all cad users which are working with ptc creo. every cad user will understand this suggestions and will love this feature 😉 you can save a lot of time, because you have to do a lot of measureing during construction process to check space requirements again and again. this is daily business for a design engineer.
5. What business value would your suggestion represent for your organization? saving time with quicker and more efficient measuring
olivierlp
Community Manager
Thank you for your idea and the information you provided.
olivierlp
Community Manager
kamleshjoshi
We can use the mapkeys, or shortcut on mini toolbar.
But still, it is required because it will help to access the information quickly.
