Measuring the distance between cylinders
When measuring the distance between cylinders, It checked in "use central axis" by the default.
It is made to want the default of OFF to be possible in a config.
2 Comments
NicolasBourgeoi1
We use a mapkey in Creo5 to uncheck "use central axis".
In Creo2, the mesures have changed and the mapkey dose not work as well ...
SPR 2154213
PTCModerator
Emeritus
Status changed to: Archived
