Mechanism - Set Gear Pitch Circle via Parameter or Relations
Please provide the ability to control the gear pair pitch circle via a parameter (that stays permanently linked) or via relations.  Today if the gear size changes (either manually or automatically), there is no way to automatically update the gear pair definition.  Manually entered values have to be typed in, every time, for every gear pair.  Very un-parametric.
6 Comments
kleipold
3-Visitor
I strongly support this idea.  It should be doable as User Defined as well.
whauser
3-Visitor
I support this request.
StephenW
23-Emerald II
 You can use the "vote" button at the top of the original message to support the idea.
Paul6
6-Contributor
I support this improvement, would help a lot.
TomU
Corresponding knowledge base article:  https://www.ptc.com/en/support/article/CS364850
olivierlp
Community Manager
Status changed to: Archived
