Mechanism standard functions.
0 Kudos
Have the possibility to connect various standard functions.
Example (see pic): low dwell, rise (SCCA), high dwell, fall (polynomial).
Now you can do this with:
  • 4 different servos
  • table function by imported points generated by external program
  • userd defined function where you must specify functions that are already defined within program like standard functions.
Why not having only 1 motor with 4 already defined functions acting on 4 dominions?
