Merge/Inheritance Placement should be as robust as assembly
When using the external placement functionality of a Merge/Inheritance feature, the placement functionality is not as robust as assembling a component in an assembly. For instance, you can only preview the model in the main geometry window. You can't select surfaces in the main geometry window. You don't get the option to toggle between seeing the component in the small window or the main window. It would be helpful to see and manipulate the placement in the main window.
4 Comments
TomD.inPDX
You're not asking for consistency, are you
jwagh
I try to avoid the hot keywords
Lohbauer
1-Newbie
Also add a way to designate the realtionship in Windchill.
olivierlp
Community Manager
Status changed to: Archived
