Middle Mouse button to close Measurement Dialog Box
Document CS100751 supports the problem that the measurment dialog box works differently than all other boxes and dosen't close with the middle mouse button.  I find that this deviation from the standard work-flow to be quite frustrating since it adds unecessary time and mouse motion.
My suggestion is to add an "OK" or "Close" command/button that  is automatically active in the measurment dialog that will close it when clicked. This will allow the middle mouse button to behave as expected.
6 Comments
dgschaefer
I'm curious that you found that there is a 'standard work-flow' with the middle mouse button.  It can mean new (view manager) or cancel (component repeat), close, create (ballons & notes), place (symbols) and likely other things.
I like your idea, but in my mind what we need is consistent MMB behavior cross the board.  Like this idea of mine :
http://communities.ptc.com/ideas/2422
obienate
Can I vote this idea up 100 times so somebody actually pays some attention to it?  Sometimes the smallest changes are the most frustrating ones because they are also SO easy to fix.
FPerez
DONE IN CREO3  🙂
GaryLinscheid
It also works in Creo Parametric 2.0 M120.
PTCModerator
Emeritus
ToddKraft
Status changed to: Delivered
