Document CS100751 supports the problem that the measurment dialog box works differently than all other boxes and dosen't close with the middle mouse button. I find that this deviation from the standard work-flow to be quite frustrating since it adds unecessary time and mouse motion.
My suggestion is to add an "OK" or "Close" command/button that is automatically active in the measurment dialog that will close it when clicked. This will allow the middle mouse button to behave as expected.
