Model-Operations-Scale Model
0 Kudos
I would like the scale operation to show up in the model tree.
At present there is no indication to show that a scale operation as been carried out.
This could lead to problems if several colleagues work on a model file. Also the scale operation cannot be altered or undone if an incorrect scale factor is applied.
Kind Regards
John Simpson
3 Comments
StephenW
23-Emerald II
Tmetcalf
Emeritus
Thank you Stephen Williams‌ -
I will keep Scale Feature open because it has the most votes; both duplicates will be closed.
Best,
Toby
olivierlp
Community Manager
Status changed to: Archived
