Model check view boundary
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
- Emerson Innovation center ,  Working as Cad Admin and Windchill business and System Administrator
2. What version of Creo Parametric are you currently running?
- Creo Parametric 4.0 to creo parametric 8.0,
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
- Model check view boundary does not calculate the drawing GD&T , surface finish and partial view axis as entity outside the drawing boundry
4. What is the use case for your organization?
- We have customized Promotion request according to Model check error , in this case actually there is error but model check is not reporting the issue.
5. What business value would your suggestion represent for your organization?
3 Comments
olivierlp
Community Manager
Hello @nimish,
Thank you for your idea and the information provided. I would still encourage you to give more details on the context and the value your idea would have for your organization, to make a better case for your fellow Community members and PTC Product managers.
lwestbrook
Hi @nimish
Have you opened a case with Tech Support? It sounds more like a bug than an enhancement request to me.
Luke
nimish
9-Granite
Hello @lwestbrook
yes i have opened case to PTC , i got answer from PTC that " I would like to confirm that as per current Creo Parametric product specifications, GTOLs, SFs and geometry axes are not listed in BOUND_INFO check."
Also PTC provided article : CS368669
Hope this enhancement will be added in next release of creo may be above creo 9
Nimish
