We would like to have a configuration option in ModelCHECK for checking of all family table instances when the generic is checked and when an instance is found in an assembly. This has to be a complete check including all checks that ModelCHECK is set up to preform.
DETAILED DESCRIPTION:
This is applicable for the following two use cases:
1. When running ModelCHECK on a generic part. A complete check on all family table instances should be preformed.
2. When running ModelCHECK on an assembly containing a part instance. A complete check on the parts generic and all family table instances should be preformed.
