Instead of some individuals using 'weird' scales in views or sheets within a drawing or accidental typos, like 9:33, it would be nice to add a check to define standard list for view scale in drawing.
While I agree that this is a needed check. it would be company specific as there is no drawing standard for views that I have been able to find. If there is an ASME standard for drawing view scales, I would love to see the reference. I did find an ISO standard that listed view scales, I think. It was many years ago.
At a prior company, we had the following in our CAD guidelines document.
Drawing view scales shall be limited to the following sizes for metric drawings:
It should be treated like the parameter, layer, name lists... where it can be configured in the administrator 'start' files based on the business need of the organization.
Thanks for pointing out the iso standard. I believe the values should be customizable by the admin for those companies that don't follow iso standards or for those that want to allow just a subset. Also, thanks for all of those likes ;).
