Please add the follow options to ModelCheck PARAMCHECK:
Ability to specify whether a specific parameter gives a warning or error. A company may have some required and some parameters may be optional. Currently PARAMCHECK gives all warnings or all errors for all parameters.
Designate syntax works inconsistently with ModelUpdate.
PRT_PARAMETER PARAM1 STR EQ PDM - STR works properly in most ModelCheck modes and is more intuitive for users.
ModelUpdate requires PRT_PARAMETER PARAM1 NONE EQ PDM - Otherwise the value of PARAM1 will have to be equal to PDM if using STR. Using the NONE syntax is prescribed in CS33856 but I've seen most ModelCheck examples using STR. Maybe allow STR or NONE in all scenarios?
Unable to check simple things on reserved Creo parameters
Unable to designate parameters like PRO_MP_MASS
Unable to make sure parameters like PRO_MP_MASS are not equal to zero.
