ModelCheck - check for Missing Internal References in Features!
I can't believe this isn't part of modelcheck.
There is a check that looks for missing references for Annotation Elements, but NOT for missing references within normal features that are internal to the part itself. I have a case where a user created a hole in a sheetmetal part that went to a depth that referenced a surface. Something happened and that surface no longer exists.
  • ModelCheck doesn't flag it.
  • There are no regeneration warnings or errors
  • Full regeneration works fine.
YET...
  • If you redefine the feature, you can't press the green check to complete the feature without fixing the missing reference.
  • Also, if your design intent changes, the feature will not update properly...
And this isn't in ModelCheck (or a warning in the message window).
Any chance we can get this added sooner than later? Users are releasing models with missing internal references!
5 Comments
lwestbrook
d.dolinger
3-Visitor
Actually, that's sad. I fased with a similar issue. Hope you will get enough kudos.
manjunathrv
Now i see the need for this.
Voted.
CR_10415978
2-Guest
Does any one know if this feature has been added on Creo 9 or 10?
rusmansait
6-Contributor
This option must be there in Modelcheck
