Modelcheck: Check First Assembly component is using default or coincident with default datum planes
As a request by @lwestbrook, I am breaking up the massive Modelcheck idea thread here:
https://community.ptc.com/t5/Creo-Parametric-Ideas/New-ModelCheck-Ideas/idc-p/692247#M13722
For this idea use modelcheck to Check that the first Assembly component is only using default or coincident with default datum planes. The first component should not be placed with dimensions to the default datums. There should not be dimensional design intent for dimensions at the first component. These dimensions should be somewhere else.
