Apparently, if there is a shaded view in a drawing, and you generate a dxf, the shaded views are exported as images that the dxf uses. However, if you have windchill and are using the cadworker to generate the dxfs, those image files are not available to download with the dxf. Therefore, we need some way to check for shaded views in drawings before they are released and the cad worker generates dxfs.
Thanks!
