Modelcheck: Check thatModel Name should be the same as File Name and Number
As a request by @lwestbrook, I am breaking up the massive Modelcheck idea thread here:
https://community.ptc.com/t5/Creo-Parametric-Ideas/New-ModelCheck-Ideas/idc-p/692247#M13722
For this idea use modelcheck to Check that Model Name should be the same as File Name and Number (3 columns in WindChill). It would be even better if we can also deal with file extensions and non-compliant characters in Windchill. In other words. Filename="Name".PRT or "Name".ASM and vica versa. The name SCREW7.5IN would need to have a file name SCREW7_5IN, where the period gets converted to an underscore. Some way to have a rule that connects the three together, but allow for these exceptions.
