When configuring ModelCHECK, some list values allow for wildcards / placeholders like:
but these cannot be used when checking for unwanted layers:
PRT_LAYER_UNWANTED [layer]
ASM_LAYER_UNWANTED [layer]
DRW_LAYER_UNWANTED [layer]
Allowing to use placeholders like # in the check file would make ModelCHECK much more aligned with itself and be useful because the admin would not need to explicitly list all possible layer names that are not allowed.
This should also be allowed for other unwanted... checks and when using external list files for them.
