Creo Modelcheck has no simple functionality to check the 3D model and say if it's a solid or not.
I can't believe that this check criteria is not a product specification for Creo Parametrics (see CS336589).
The existing SLA_INFO checking is not working. Here the explanation from PTC:
"although the model obviously has mass properties (so to say Solid YES) at the same time it sometimes cannot be fully triangulated like an ordinary solid (SLA_INFO NO)."
Please vote to make the Creo Modelchecker better!👍
Thx😉
