Modernize the create drawing view workflow
Insert a general view, then create projection view one by one is very very old style workflow from Pro/ENGINEER 2001, then Pro/ENGINEER Wildfire 2.0-5.0, to now Creo 1.0 - 3.0. It has never been changed at all since twenty years ago and is low efficiency for us.
It is time for PTC to Modernize the create drawing view workflow, just like other software, provide user to select create all the main views for example front, right, left, back, top in one page in the first step.
7 Comments
MartinHanak
24-Ruby I
Try to define drawing template. Look into Help for details.
qzhou-2
drawing template is just a workaround. Define a drawing template is very difficult for general user. So Change create drawing view workflow is needed, just like Solidworks, SolidEdge, NX
bduncan
sricca
1-Newbie
Maybe, during the activity to modernize this issue, it would be the time to review all 2D system drawing. And, maybe, to permit to produce 2D drawings stand alone. I'm asking this just since 2005 (CATIA already did...): I could accept a 2D that works slightly worse than AutoCAD, but it can be very difficult to accept that it is so far.
ptc-5127287
1-Newbie
Drawing model need to change. There are no really enhancement many years ago
ptc-4226637
1-Newbie
The workflow of Creo Elements/Direct Modeling annotation is very perfect. PTC should re-use it in Creo Parametric.
PTCModerator
Emeritus
