I would like to be able to modify a relation driven dimension without going to the tools tab, opening the relations dialog box (change the look in to Section when in edit mode), finding the correct relation, then making the change, and returning to what I was doing.
Ideally the relation would be shown in place of the dimension and you would be able to change the relation or replace the relation with a number.
A simpler approach could, when trying the edit the dimension, open the relation dialog with the relation highlighted.
I use relations to drive some dimensions in my part sketches to create the appropriate dimension that can be shown on the drawing and still keep the design intent, such as symmetry or length of thread on boss.
