Modifying the view display style should only apply to the currently active window. Or, at least make this a config setting which the user can turn on/off.
It would be so much better if the view display style setting "sticks" for each window I have open. Changing the view display style for one window should not change the setting for all open windows! It results in a lot of unnecessary clicks when flipping between different parts and assemblies.
