ModuleWorks turning enhancement
ModuleWorks need to support material removal of sequences using the same tool but with different NC Sequences CSYS
Currently, for all sequences using the same tool, ModuleWorks don't change the tool orientation even if NC Sequence CSYS change (the calculation of the tool orientation is only based on the first NC Sequence CSYS)
8 Comments
mreiter
I think this is a bug and not an enhancement
Christian_TS
3-Visitor
this is a bug!
to copy the tool is a workaround!
mreiter
This Problem is maybe fixed in Creo 3 M170, wenn this Version is aviable I´ll make some Tests.
mreiter
I tested it, it´s implemented in Creo 3 M170
lgerard
3-Visitor
You are right, something has been fixed in M170. Nevertheless, this fix is now a big issue for me.
Indeed, now Moduleworks remove material around NC SEQUENCE CSYS Z AXIS and still not support TOOL_ORIENTATION so it's worse than before
1) You cannot orient your tool with NC SEQUENCE CSYS because MW use Z axis as spinning axis
2) You cannot use tool_orientation because the first tool_orientation is used for all sequences using the same tool
creo
Referring to above picture ,
mreiter
I noticed this and started a new call
lgerard
3-Visitor
OK, can you give me the case number ?
mreiter
Look at this cases:
14163852
14163839
14118217
14040416
