Mold manufacturer need to bend solid geometry on a specified surface with draft control. Espacially modifying side walls according to pull direction while bending solid geometry on a specified surface is very important for mold makers to not to waste time for detailed shaped models.
In attached video you can see Creo and Siemens NX comparision for this subject and easily notice that in Siemens NX this option is provided in a very easy way.
