Move all menus under File > Help to the upper right corner of Creo Parametric
For relatively high frequency of use Menus under File > Help is not convenient
3 Comments
Alexandrite
What commands are you accessing under the file > help menu?
Did you know that if you place your cursor over a command/icon and hit F1 the help center will open with the topic for that command?
Newbie
Jim, Thank you your sharing this tip to me.
My target is move Help as cascade menu on upper right corner. My key menu is log support case, search online knowledge base, and system information.
Community Manager
Status changed to: Archived
