Move some specific ordinate dimensions to detailed view excluding baseline
For current functionality,there are the following restrictions about ordinate dimensions:
) An ordinate dimension must be in the same view as its baseline.
2) An ordinate dimension in a clipped view (such as a detailed view) must (in extension) intersect the view boundary.
• If all the references of ordinate dimensions (based on same baseline) exists on detailed view, user can move all ordinate dimensions with baseline to detailed view together.
• If some references of ordinate dimensions are not present in detailed view, user cannot move ANY ordinate dimensions using one baseline to detailed view
• So if there are a lots of ordinate dimensions referring to one same baseline, user cannot move some specific ordinate dimensions to detailed view only.
Refer to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS216987&lang=en_US for detail.
Please remove these restriction in the future version. Allow to move some specific ordinate dimensions to detailed view excluding baseline.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
