Creo Elements/Direct Annotation and Creo Elements/Direct Drafting should allow multi-line composite GD&T symbols in order to meet the ASME Y14.5-2009 standard.
Currently composite GD&T symbols are limited to two lines. The new standard allows composite symbols with multiple lines.
It is not possible to use the current function and stack symbols in order to look like a multi line symbol, as the standard requires that the Tolerance box be extended to include all the lines in the composite.
