Multi segments thin protrusion
Multi segments thin protrusion – Enhancement request
Requirement:
Ability to create multi segments thin protrusion, for example:
These segments can be stand alone, and/or crossing each other, and/or chained as demonstrated in the upper figure.
Usage:
One frequent usage is EMI walls for RF cards.
Current Creo limitation:
Creo does not support un-chained entities or crossing entities.
Creo RIB is not a solution since it extends the entities for example:
And also fails if add entities as follows (see attached file)
And also, to use a RIB you' must create an artificial fence around the face.C create a RIB on just planar face.
Attached a SOLIDWORKS file that presents the requirements:
4 Comments
olivierlp
Community Manager
Hello NR_8959408 and welcome to the Community.
Thank you for publishing your idea with a good level of detail on the problem. However, before acknowledging it, Please additional information as specified in the form you saw in the submission process. (Questions below). The more details and context you give, the better.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
S_Edgenear
This shiuld work as long as the generated geometry is centered around the sketch lines.
It could be added a condition on the sketch exit, that if the lines cross or there are multi-segments, the "left, right" options should be disabled, and only centered thin geometry be created.
olivierlp
Community Manager
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
olivierlp
Community Manager
Status changed to: Archived
