The present multiline text function (https://support.ptc.com/help/creo/creo_schem/usascii/index.html#page/Schematics_hc/To_Add_Text_With_...) allows the user to adjust the text box size/shape while it is first being placed (but no instructions about that in the help notes) but then it is locked in place.
If you start a new line in the input box to separate items that should be on different lines, they are concatenated together without a line break.
