Multiple k-factors in one component
Sheetmetal
At the moment when you bend a plate, you can set the k-factor and the cut file (dxf) is fine.
Problem:
What do you do when you have to cut a plate and there are 2 processes linked to it.
1. A normal bend.
2. Rolled section.
Answer:
Now you have to have an option to set the k-factor for each process.
PTC can you add this option to Creo in the future?
Marinus
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
