Why cant i select multiple surfaces when adding axis to models, so show centerlines on drawings. a triangle hole cut, with the rounded corners.. i go to add axis, and have to click axis, then click surface, then middle button, then click off the model in space.. then click axis, then surface, then middle button. i should be able to multi select surfaces to add axis on these features.
