Allow custom naming convention for auto-generated sheet metal flat instances. Currently, the behavior is to suggest the naming convention <filename>_flat1. The prompt does allow you to change the name before creation, which at least lets the user correct it, but it would reduce user error if the auto-naming suggestion conformed to our business logic.
Current Version: Creo 4 M060
