Currently PDF's that are created\exported directly from MM use the following naming convention:-
PTN-13038-01-A-work-DRAWING_2D-aip_dwg_annotation-pdf
NAME – Version – state – Class - aip_dwg_annotation-pdf
is it possible to configure this the naming convention via XML?
