There is a pdf called "PTC Creo 3.0 Parametric Configuration Options" (attached). Since I don't have all of these options, their definitions, and all possible values memorized, this pdf "glossary" is very helpful.
It would be similarly helpful if PTC could produce a pdf glossary for the drawing detail options; while I realize they are less numerous, they are no less mysterious.
Thank you!
