New window while using second monitor stays with session of Creo versus jumping to primary monitor.
0 Kudos
While using Creo on a secondary monitor, and you open an file in a new window the window opens on the primary monitor not the secondary monitor where your session is running.
Creo 7 and beyond.
Give the user (or at least a config setting) the ability to open a new window (file) on the same monitor as the current session is running.
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @dplachinski for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
