No datum plane, no surface finish, no geom tolerance by default when insert new views in drw
Everytime you add a general view in a drw you obtain by default all the reference planes, surface finish and geometric tolerances of the asm.
This is annoying: you have to remove them all from the drawing (it takes time when they are thousands...) and then you'll keep probably none.
The workaround is to create a layer to hide, but then you loose the "show/erase" functionality.
Please add a config option where you can change this behaviour.
3 Comments
fbertolino
1-Newbie
The PTC support informs that we can erase by default GTOL and surface finish by setting auto_show_3d_detail_items NO.
I'ts not possible to erase datums by default anyway.
olivierlp
Community Manager
Status changed to: Archived
