No limit for CAM tool tips
When you set up a multi-tip tool, you can specify up to 8 tips, or stages. As workaround, you can define two similar tools with the same tool_ID and different Tool_Position or with two different tool_ID and the same Tool_Position (because two tools cannot have the same Tool_ID and  the same Tool_Position).
There is sometimes need to simulate tools with up to 16-32 tips... therefore, why there is artificial limit?
2 Comments
Perttu
Also, there is an idea to simulate full turret with all tools in it using tool flashing. It would be an easy way to achieve good enough simulation in multitaskin turn/mil machines.
PTCModerator
Emeritus
Status changed to: Archived
