When you set up a multi-tip tool, you can specify up to 8 tips, or stages. As workaround, you can define two similar tools with the same tool_ID and different Tool_Position or with two different tool_ID and the same Tool_Position (because two tools cannot have the same Tool_ID and the same Tool_Position).
There is sometimes need to simulate tools with up to 16-32 tips... therefore, why there is artificial limit?
