Note Properties screen is no longer displayed by double-clicking the note
In Creo Parametric 2.0, Note Properties screen was displayed by double click, but it is no longer possible from Creo Parametric 4.0.I want you to be able to do like Creo Parametric 2.0.
2 Comments
kdirth
The double click allows editing within the drawing, as it will be seen.  To get to the properties dialog box, select the note, right click, and select properties.
An option to set the preferred action when double clicking on a note, on screen editing or open properties would work.  I prefer the newer method as I don't change the text properties very often.
Mfridman
Status changed to: Alternate Solution
Hello @kamsanfd ,
In Creo 6.0 we have modernized the notes and introduced a contextual ribbon design for the notes. All of the note properties are in this ribbon, so it is easy to update whatever you need
Best Regards,
Michael Fridman
Creo Product Manager
