When a model is modified, not checked out, but uploaded; the notification center gives a server warning. However, the notification center brings in the menu button to "Update" to the latest, as its solution for this warning. However, you can't "update" an uploaded-modified cad object. Nothing happens. The warning stays as-is. The solution should either be to check-out the object or to add the object back from commonspace.
