Creo already knows how many instances are in a point pattern, whether driven by datum points or a sketch with datum points. If you right click and go to feature information, it says that the sketch or datum point set is the leader of a (N x 1) pattern.
That number, N, should be stored as a parameter so that we can call it out on drawings. Currently, there is no clear cut way to access this information.
