Many of our customers wish to change the default coordinate system orientation, for example Automotive customers who need their templates to be compliant with DIN70000/ISO 8855 standards.
Changing the default coordinate system orientation also extends to other domains/sectors, for example customers in the BIM world or customers working with a lot of other CAD systems (where the Z-axis is normal to the TOP plane).
Although it is technicaly possible to manipulate the orientation of the default coordinate system (by using configuration options orientation user_defined, x_angle <value> and y_angle <value>), to get a correct setup is very tedious and sometimes it is simply not possible to meet the requirements of these clients as the current mechanism is too limiting (no z_value can be set)
It would be incredibly valueable if it was possible to simply set the standard to which the default coordinate system should be oriented to (automotive example), or at least enhance the current mechanism to allow for simpler, yet more complex configurations/orientations.
