Offset lines in exploded state removed from display if the view display is set as shading
Current state:
In the drawing view, if the view display is set as shading, then the offset lines are not removed from display, if the line passes through the model.
Request:
Offset lines should be removed from dispaly for shading view as it currently works for display set as hidden.
3 Comments
Dale_Rosema
Tmetcalf
Emeritus
Good day all,
Another fine catch by Dale Rosema‌ - please vote here In shaded views in a drawing, the offset lines are not hidden.
olivierlp
Community Manager
Status changed to: Archived
