Sometimes I lose track of how big or small the object I am working on actually is...
I wondered if it might be possible to have an onscreen scale indicator (perhaps parameter driven) along the bottom or side of the graphics window that could give an idea of size at a glance. It would obviously need to change depending on the zoom level, and be dependent on the units for the part. Being able to turn it on and off at will would be nice too.
Just curious if this is possible.
